Old 11-19-2010, 09:41 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by Rare Iron View Post
Please Bob - do tell! I've never heard this before.
AFAIK, there are only 4 true synthetics on the market: Amsoil, Redline, Rpyal Purple, and another I can never remember the name of.
Originally Posted by zrayr View Post
the far the best feature of synthetic oil is reduced friction, which in turn reduces wear.
whether or not Mobil 1 is a true synthetic is mainly an advertising issue. Z.
Not true at all. It's a trick of marketing types and lawyers that make you think M1 is synthetic.
A true synthetic starts with a PAO base stock, no dino oil. Then it's further refined, and the package is added. The key is there is no dino oil.
Oils like M1, QS, etc start with standard dino oil. Then they refine and add until it meets the legal requirements as established by the courts to be allowed to use the term "synthetic". It's a marketing trick, don't fall for it.
However, that's not to say they are bad oils. They're not. They do perform better than standard dino oils. But not as good as a true synthetic. Most people don't need the performance of Redline or RP. If you can get M1 pretty cheap, there's no reason not to use it. This is not a case where you get what you pay for.
As for reduced friction, that's true. Semi-synth's are better than dino, but not as good as true synth. If you're racing and need every last hp, it's worth the expense for a true synth. If it's a street car that gets less than 5K miles a year, you'll get the same performance using standard Penzoil (or maybe wallyworld) and changing it once a year.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
