Thread: Red Loctite
Old 11-19-2010, 01:41 PM
BBQCYCLEWERKES BBQCYCLEWERKES is offline
Cobra Make, Engine: 2007 BDR FR Boss 302
Smile
I use my commercial heat gun. This way I don't have to worry about starting a major fire. Takes a little longer but it works also. If no heat gun how about a hair dryer set to high. Unsure if this will get hot enough but worth a try. Good luck. I hope you don't strip the head on the bolt. P.S. make sure you chase the treads in the item the bolt is screwed into also. This will make it easier to install and remove again if you need to.
