Old 11-19-2010, 03:04 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Progress 11/19/10
New Steering Rack installed
The Dash Leather is ready to ship to receive Robert Downey Jrs Autograph
How do you get a nut and washer on a bolt that is inside a hole which only a two year olds hand can fit in???
TAPE!
Gorgeous new engine mounts from Kirkham.
SOME GOOD LUCK! Kirkham already welded the brackets in place for the Tremec Mount.
excuse the dirty frame-there is primer overspray on most of it and i still have not had a chance to give it a good scrub.
The Sidepipes are off and will be listed on ebay this evening starting at 1.00
MSD digital 6 Ignition Box officially mounted in place
Oil puke tank installed
I'm not sure if it is going to work though. I think it might be a little too far to the passenger side. I will need to wait and see how everything else lines up once installed.
