Old 11-20-2010, 09:22 AM
charles roybal's Avatar
charles roybal charles roybal is offline
Cobra Make, Engine: FRR MKIII 408w
Originally Posted by davecobra View Post
Charles I would check the pickup also, have had several fail on other cars.
Sorry to hear that, but that is part of the breaking one in, also I would check all the engine grounds to may sure they are tight. I saw one coil fail because it was mounted horizontal instead of vertical and it overheated.
Let me know if I can help.
David
432 386 6777
David,I was thinking it's the coil as it is mounted verticaly on the right AFR head..well work on it today.
I have a cut off switch form the batt. so no power to anything when car is not running.
