Old 11-21-2010, 04:46 AM
Loadco's Avatar
Loadco Loadco is offline
Cobra Make, Engine: ERA 427 SC
How are you attaching the O2 sensor form the LM2. If you are just using the Innovate tail pipe clamp your readings are probably not accurate. I had that problem with my LM1. You need to attach a length of tubing to the inlet on the tail pipe clamp to get it up inside the side pipes to get a good reading.
ERA #509
2003 Z06
