Old 11-21-2010, 10:33 AM
madmaxx madmaxx is offline
That is the one I use on a 8120 steel billet cam and there are zero signs of wear on either. Be very very very carefull. If you had a cast iron gear and a steel gear next to each other most could not tell the difference. So make sure the package is sealed when you get it. This does not apply to this incident since KC will address.
I wouldn't mind hearing whether the new gear is going to be another composite or whether it's going to be one of the steel ones that Max was mentioning on the other thread and which is pictured below. http://www.msdignition.com/Products/...utor_Gear.aspx
