Old 11-23-2010, 09:51 PM
LMH's Avatar
LMH LMH is offline
I don't think so. The suspension travel isn't much and I think that's plenty for driveshaft length. Make sure the pinion angle ok and I don't see that as being a problem.
Will you be able to remove the engine and/or transmission w/o removing the body? Might be something to keep in mind as once steering, brakes, clutch, wiring and so on are installed, removing the body is a real pain.
Alba gu brąth
