Old 11-27-2010, 10:47 AM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Originally Posted by Three Peaks View Post
Any suspension pieces available?
Bob
These are the latest modification we did to the original style rear lower control arms before we switched entirely to billet suspensions. We replaced the bearing with an adjustable rod end to more easily adjust camber and caster in the rear suspension. Rear caster is adjusted by lengthening and shortening the bushings in the rod end. We replaced the original bearing because it really didn't have enough travel and the bearing beat out over time.
Retail on these 427 Rear lower control arms is $500 each. I will let these go for $350 each.
David
