Originally Posted by GT350Mike
David,
I'm interested in the following parts:
- Headers and sidepipes
- Intake 427 FE engine intake manifold
- Alternator pulley and harmonic balancer pulley
- Driveshaft
- Right side Exterior mirror
- Shifter for a TKO 600
SIDE PIPES:
We have a set of stainless side pipes, polished. One of the side pipes is dented on the bottom, (you can't see it when you look at the pipe when it is mounted on the car). You have to crawl under the pipe to see it. The other pipe has the holes stretched out a bit on the muffler. The pipes are $2000 retail. We will let them go for $1000. They do NOT include the head tubes. 1 set only.
HEAD TUBES. We have a used set of head tubes that are not polished. Stainless steel. Retail $1500. Today--$750. 1, maybe 2 sets only.
427 FE INTAKE MANIFOLD
We have a dual 4 intake. Low Riser. $200 1 intake only.
ALTERNATOR PULLEY
Aluminum--probably a March pulley. $15 We have 3.
HARMONIC BALANCER PULLEY.
Aluminum. Fits Big Block Chevy. We slotted the holes and used them on the FE until we made our own. $15 We have 3
DRIVE SHAFT--We don't have any scratch and dents right now.
REAR VIEW MIRROR--which one do you want?
SHIFTER FOR TKO--which one do you want. Our straight shifter is $100. Today--$50.
David
