Old 11-28-2010, 03:57 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
I used the mass flo efi system on a previous build and i would not hesitate to use it again. You are somewhat limited to air cleaner choice, but as long as you dont mind using it with an Oval Shelby style air cleaner, you are good to go. A very simple system to install and the engine started on the first crank and i had it on the road 5 minutes later. I never had to mess with the system. A little lag on the return to idle, but only a few second delay-it would hover around 1500 rpm for a few seconds.
I have tried one other EFI system, but i will not mention it here. Feel free to send a private message if you would like to hear about it.
