Old 11-28-2010, 04:43 PM
Baz's Avatar
Baz Baz is offline
Originally Posted by Zedn View Post
I have got some rubber that i plan glue along the bottom. Making a channel for the rubber was just too much work. It should look the same when finished.
I have left a 5mm gap all around to allow room for screws for mounting sunvisors and attaching the side bars. I havnt yet tapped these because i dont have any brackets yet for the hole locations.
Well done Liam and congratulations on the new daughter.
Don't worry about fitting or even drilling the holes for the wind wing mounts as you will be knocked on these by RTA as non compliant ADR -That is speaking from experience.
Lovely work on the screen fabrication also.
Baz
