		Paul, another alternative is to determine if any of the various motorcycle baffles might work. As an example, Harley Davidson has a low end " Power Baffle " part # V21299 , along with other baffles that are more/less restrictive. Baffles might require modification. Or, a combination of baffles that have been mentioned.
There are reverse flow mufflers, which would need to be modified, used for Corvette side pipes.
Take it that you are going to place the baffle internally and/or modify the turn out. Challenge will be not knowing how effective the solution is and the impact to performance/HP, such as reverse flow mufflers,  until the side pipes are reconstructed
