Old 11-30-2010, 11:08 AM
blykins blykins is offline
Default FS: Freshly rebuilt HEH-BW Toploader
I'll have an HEH-BW Toploader ready to go by the middle of next week. It's a wide ratio, 1-1/16x10 input, 28 spline output. It will have new blocking rings, SKF bearings, countershaft pin, seals, snap rings, needle bearings, etc. I'm also replacing the input shaft bearing retainer and 3rd gear. I can set it up with either a 6T or 7T speedometer gear. It will be cleaned, painted, and ready to roll.
The casting numbers for the case and tailhousing are: RF C5AR-7006-D (8 hole case) and C4ZR-7A040-A.
$839 + shipping.
All work is done by me, so you know where you can find me.
I'm also a dealer for Hurst and Long, so I can order and install a shifter at your request.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
