Old 12-01-2010, 02:42 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Holt,
Since you are well aware of the problems with S.B.'s Cobras, I wont go there! A solution that I have done is take as large a 10 ga. flat plate of steel, as big a piece as you can put in/against the firewall on the inside.
Take the master cylinder off, pull the Pedals out, us one or both parts as patterns for the steel. Bolt it all back together again using the plate as the sandwich. This should take care of your problem.
If NOT then make a larger but matching plate for the outside of the firewall and then bolt everything together. Problem solved.
My 2-cents
DV
