Old 12-02-2010, 02:31 PM
jhv48 jhv48 is offline
Originally Posted by mark_n2 View Post
Does the kit with the BAT fittings, or I need source separately
They will supply all parts needed and attached. Ready for you to thread through the fire wall and screw to your gauge. You may need a standard fitting onto your block (supplied by most oil pressure gauge kits) if your current fitting is UK. BAT will know when you tell them your current setup. Tell them it is for a SPF and you wil be suplied with the correct length (6 ft.) and all fittings will be attached for you.
Jim
