Old 12-02-2010, 06:26 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Originally Posted by David Kirkham View Post
Happy to help. Frankly, we are not even 1/2 way through. I keep finding things. I am not sure what you mean by "round coupling?" Do you mean the steering u-joint? When you say round do you mean the round 48 spline? We can send you a 48 spline to "D" conversion u-joints.
I'll look for a gas tank and more side pipes. Did you see the post on all the bends? You could use those to finish up your head tubes. Then all you will need is a merge collector you can weld to the muffler.
David
Dont worry about it David! -I am just going to UPS the rest of the steering system to you to have it inspected. Its not really something i want to mess around with.. It's not worth the risk to save a few bucks. it will be on the way tomorrow.
I thought the other 427FE head tubes were more or less complete and just needed to be welded and or fit then welded. Am i wrong? Maybe i should just buy new headers already made. Will these fit the pipes that you make or will i need to order pipes elsewhere?
Thanks
Chris
