Old 12-03-2010, 03:51 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Wish List:
Full blown Cammer, with EFI Stacks, single or dual turbo's, or a single 9/10 lb. super charger, entire electric tilt nose such as DV II, in/out roll cage from interior through the motor dept.
Dash to be clean and minimal, with just necessary gauges. wiring, all using weatherproof connector for long long time use without headache. 17" low profile, wide tires to the rear with the rear suspension modified so it all fits under the tubs.
Inner frame rails modified and boxed to handle the T56. Absolute modified front wiring harness so NO wires show with the hood Open OR Closed. (Learned this neat little trick building streetrods!)
Front firewall modified as DV and DV II, gives much more to the interior and the engine compartment.
Modified Stange 9", moser 31 splined axles, attached with M/T super street / slicks.
Custom designed true fell cell.
Misc. neat tricks at they come up.
Cost: Probably 40k/50K Minus the kit, plus up to 12 months to build!
Any suppliers/sponsors?
Still time for one more "Very Special Snake by DV!"
Blasphemy, but maybe even a KMP body with one of their super ID-rear end!
A driver that would be fully capable of pushing the monster to it's limits!
Never stop Dreaming! DV III ?
