Thread: Jag Diff Noise
Old 12-05-2010, 07:55 AM
redmt redmt is offline
Default Pre load torque
Preload should be 25 inch pounds of drag when rotating just the pinion in the carrier housing. ? Rick L.[/quote]
I used to build 3rd members when I was a Ford mechanic way back when. We used to set them up with 7-10 inch pounds running torque with smooth initial rotation and new bearings. Has this been changed? 25ipt seems a little tight?
