Thread: Jag Diff Noise
Old 12-05-2010, 08:18 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Originally Posted by AC-460 View Post
Make sure who ever has shortened the tailshaft has lined up the yokes ...from one end to the other ....lay it flat.... the caps on both ends must be pointing up and down.....if one end is either way or a quarter turn different it will vibrate and chatter like crazy...
Its not the oil... its a balance/harmonics problem
If the diff is noisy it the gears .....if it vibrates its the tailshaft ....my guess is your tailshaft hasn't been shortened correctly....try one thats not done right and it will kill everything around it...
