Thread: DRB 540 build
Old 12-05-2010, 08:29 PM
boxhead's Avatar
boxhead boxhead is offline
Well Christmas parties took there toll this weekend, Chris had his staff party on Friday night and I got a message late Friday night advising not to come in till 8am.
So with only 3 hours work I managed to remove colomn, remove pedal assy and modify pedal box (remove a small amount of plastic webbing) and fit the pedal box and booster/master cylinder in place.
Then I made a bracket for the ABS module, modified part of existing bracket as per instructions and mounted that, refitted power steering pump and modified (bent) the pipe to suit.
And as you can see in above pic I also removed wiring harness from donor engine bay, mounted fuse box and routed wiring around bay and into cabin.
I am not sure how much if any work will get done next weekend as Friday night is Chris's Christmas shed party (could be a late night)
Chris was also going to order the A/C kit this week.
Again I have to say that everthing is going together way too easy to be classed as a kit car.
Cruising in 5th
