Thread: Jag Diff Noise
  #23 (permalink)
Old 12-05-2010, 09:22 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Have the driveshafts out to the wheels been phased correctly when shortened....Just trying to eliminate other possibilities... I seen alot of funny things happen...also if the unijoints in these shafts haven't been replaced they are possibly worn... then when you put them in the cobra and work them at greater angles they can vibrate because the needles are trying to work through the worn spots on the cup and the uni
