Old 12-08-2010, 08:34 PM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
Originally Posted by sevenohms View Post
6 speed auto is functional, but no speed input. Dunno yet what i'll do there.
You also need the door locks or else it'll immobilise itself so I'm using the door locks from the ute.
Nathan,
The speed signal for the falcons comes from one of the ABS senors(front one I think). If you can fit all the sensors you can have ABS plus the speed signal for the gearbox. If you have any questions about the ZF and wiring of it PM me. My brother is charge of the auto section at a local ford dealer and might be able to help.
Are you sure about the door locks and immobilising itself. When I built my 540(BF ll doner car) the car was started and driven without the door harness and door latches plugged into the main loom.
Using the door latch is a good idea although they do take a bit of room and will be a tight fit in an AC door.
You will need all the computers ( air con, abs, body computer, air bag)plugged into the loom to get the car to started. There is a company in WA (http://www.norcom.net.au/~bpt/index.htm)that can disable all the unwanted computers if required.
Warren
