Old 12-10-2010, 10:33 AM
patrickt patrickt is offline
Originally Posted by Blas View Post
As I remember, only steel-belted radial tires had prolonged problems with flat spots after a long storage periods. Non steel-belted tires should round-out again after a couple good "heating ups" on the road in the spring...As to the covering of the car question...There is a lot of airborne dust and dirt that will settle on your paint and interior over the winter with the car uncovered...covering is probably more a decision of whether you care or not about issues like that...
Blas
Yep. Mine stays in a sealed, moisture controlled, bag from Thanksgiving to Easter. Once a month or so I will roll it forward, or back, a few inches in the bag even with the steel belted radials (I do put an extra ten pounds of air in the tires). The car comes out in the spring just like it went in during the late fall. The battery is disconnected via a quick switch, a bottle of StaBil is in the full tank of gas, and it fires right up.
