Old 12-12-2010, 04:31 PM
boxhead's Avatar
boxhead boxhead is offline
But if you rebore it larger, where are you going to source the larger piston from?
Because if you keep the standard sized piston in the larger bore I think it would be asking for a leak.
Does the Harrison master cylinder mount in the engine bay or is it inside the cabin?
I fitted a Willwood one (may be a beter option for you too) as the less "modified" parts you fit the easier it is when you need to replace something.
Cruising in 5th
