Old 12-13-2010, 07:29 PM
RodKnock's Avatar
RodKnock RodKnock is offline
Duplicolor clear acrylic has held up well for 5 years, but be advised, heat will turn the as -cast centers to a gray under any clear. (See my gallery).
Instead of ERAChas, we should call you AdvisoryChas.
I saw where the Dow 7/dichromate coating saves the wheels from aging, although the lips are left natural and require some maintenance. Not a ton though since the modern casting process per M&A Castings' website states "WITH NEWER HIGH PURITY ALLOYS THAT ARE NOW AVAILABLE, CORROSION IS ALMOST NON-EXISTANT (sic)."
Read'em and weep.
Can organic brakes pads be used and do they prevent less of an issue in terms of corrosion?
