Thread: T5 overhaul
Old 12-16-2010, 08:51 PM
mikeforte mikeforte is offline
Smile T-5
Hi Gary,
Before you purchase anything you should get a quote on the parts needed to rebuild your T-5. You'll need the TAG number to identify it correctly. Add the parts needed and figure a little extra. Then consider a new in the box T-5 sells for just $1295.00.
I sell new T-5 Tremec transmissions and all of the rebuild parts too. Just add the parts up and you'll see the difference many times is worth buying new in the box...
BTW, FREE shipping in the US thru Dec 31... I do shipping allowances on export orders.
Originally Posted by hinoonaz View Post
I am trying to convince myself to rebuild the T5. Syncros are not good and probably wornout gears too. How difficult? I can put together an engine and other eye hand things. Replace main with larger shaft etc. Just looking for some advice. It seems that the labor to put one together is only 300.00. Is it worth it?
Thanks for any and all opinions.
gary
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
