Old 12-17-2010, 03:23 AM
Default Timesert the hole
Grubby Time sert the hole and use a new bolt to screw into it. Cut the head off and you have a new dowel pin. Make sure you check the bellhousing to be centered on the back of the block and crank. Yes I have done this before, work fine. Rick L. P.s Use the bell housing as a guide to drill the hole out.
