Old 12-17-2010, 10:30 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Originally Posted by Three Peaks View Post
David,
Does this differential come with Pinion shaft, seals, pinion gear/ring gears? If not, which gears does it take- Dana 44? What rear cover would be needed for this case?
Thanks,
Bob
No ring and pinion. I don't have a used one here any more. It ended up in El Gato's car.
Dana 44 gears.
I can sell a ring and pinion for $155, depending upon gear ratio. Some are quite a bit more than other. The Auburn case here is a case for 3.73 and lower (as in a lower number, not a "higher," or steeper, gear). A 4:10 gear will not work with this Auburn. You'd have to get a different differential unit (not case).
The cover is also for a Dana 44 case. You can get them for almost nothing at a junkyard. They are on all sorts of Jeeps.
David
