Thread: another leak!
Old 12-18-2010, 09:16 AM
madmaxx madmaxx is offline
The slave you will buy from autozone will have a pushrod with it, no need for the threaded rod and nuts, threaded rod works but looks like junk yard sheet.
Nice bracket, alignment appears ok, get new slave, let it wear in a little and good to go, if you bleed by just letting it run out bleeder make sure you remove the cap from the reservoir or it may hold a vacumm and nothing will come out.
