Old 12-19-2010, 04:51 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
When you bolt up the side pipes they need to be free from any tension.. What you should really do is mount the mountings to the sidepipes first,,,and then install and once you have evrything nice with no tension ..then weld the brackets to the frame...remember these are custom cars... you can't expect to just bolt everything up and hope that it will work........a little thought is necessary...
