Old 12-22-2010, 05:43 AM
RodgerH RodgerH is offline
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Hi Brent,
My TKO has the small input shaft.
It's been running....I'm replacing a noisy TO bearing. The original TO bearing appears to be the Federal Mogul/BCA 614038 suggested above. (I also found that one of the little retaining springs was broken and in the bottom of the bellhousing.)
I was told the Federal Mogul FB-1625-C was a good replacement. When I compared the two, they are somewhat different in the way the fork attaches, so I wasn't sure if it was correct, or if there was a better one to use.
Thanks for letting me know that any of the bearings discussed will work.
Rodger
