Cylinder pressure forces rings down against the groove, and out toward the cylinder walls. Light throttle or backing off the throttle will reduce pressure to the point where inertia and inter-ring pressures take over and the top rings are not pushed down & out.
The downstroke flow of some residual combustion gasses through a gap help to move scraped
oil toward the piston's drainbacks and the sump. Lacking any downward impetus, the
oil will cause the second ring to eventually hydroplane and the
oil can contaminate the combustion chamber.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
