Old 12-23-2010, 04:54 AM
elmariachi elmariachi is offline
I didn't use a stroker kit, that's not why it had to be reworked. I failed to tell my builder I was using an Armando/Aviaid type pan. He used ARP bolts on my mains and unlike the OEM bolt heads the ARP heads protrude above the surface of the rear cap, and the pan hit them. So first pass was to weld in some clearance on the rear rail. I finally replaced the bolts and decided while I had it apart to have him return the pan to normal.
