  #30 (permalink)
Old 12-23-2010, 06:03 AM
Barry_R Barry_R is offline
Sometimes lost in the discussions lies the fact that gapless rings are not a new invention. They have been around in various overlap joints, bevel joints, and multirail designs since at least the 20s if not earlier.
The ring package is a dynamic sealing device moving at a high rate of speed under high pressures and at high temperatures. Not an easy thing to optimize or quantify. What works in one environment (say an air compressor) is not the best in another.
If you look at the wear pattern of rings at the gap you will find that they are not round. More & wider wear is evident at the tail end alongside the gap. They cut them after lapping so that the unit pressure at the gap is higher - this helps to stabilize the "tails".
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
