Old 12-24-2010, 06:13 AM
mkassab's Avatar
mkassab mkassab is offline
Cobra Make, Engine: Unique 427 S/C, 427ci
I'm doing many items:
Adjust valve lash, new valve cover gaskets
Change Oil, filters, trans and rear end oils
add a new timing mark and timing tape to the 11:00 position
change, fabricate bracket and add a new clutch slave cylinder (I'll post a separate thread on this)
Safety wire my rotors to hub bolts
add/install fresh air ducts to foot wells (I'll post a separate thread on this)
chk all bolts/nuts
repack front wheel bearings and seals
balance and alignment
bleed brakes and clutch with new fluid
Fabricate and install small motorcycle side mirror to windshield frame
Mark
Unique 427 S/C, B2 Motorsports 427ci SBF, TKO600, Jag IRS 3.73 Posi, Avon Tires.... and so much more http://www.uniquecobra.com/forums/forumdisplay.php?f=68
