Old 12-24-2010, 07:37 PM
Outwest34au's Avatar
Outwest34au Outwest34au is offline
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
Originally Posted by thefordguy View Post
if I had another u joint I could go around the pump I just need to figure out where to mount the hiem joint.
I cut a piece of 8mm wall thickness square steel to 50 mm long, then sliced it diagonally to have a tapered bridge. This sits on my siderail and welded on. To prevent the heim joint flexing on the mount I drilled out a large nut and welded it to the bridge mount, insert heim thru it with nut top and bottom. If you find the thin 'jam' nuts hard to source try your local Caterpillar spare parts place. Easier than cutting nuts in half.
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
