Old 12-26-2010, 07:45 PM
snowgoer's Avatar
snowgoer snowgoer is offline
Cobra Make, Engine: BDR 983 392 430hp/450T, World Class T5
Default Do you think this 302 is 400hp
I am looking at buying a Backdraft with a 302 in it that supposely has 400hp. The motor was built by Rolling Thunder Race and Engineering from Boca Raton, Florida in 2004. The owner faxed me a spec sheet from them and below is what it has listed on it. I was wondering if 400 hp is close based on these specs. Any other thoughts on this set up???
ARP oil pump shaft
Melling HV oil pump
Weisco Pro-true forged pistons
molly file fit rings
Clevette 77 rod and main bearings
302 performance i-beam rods
tricFlow Stage 2 cam
ARP cam bolt
Ford racing hydraulic roller lifters
Ford racing lifter hold down kit
Cloyes double ro;;er timing chain
Romac harmonic balancer
Ford Racing flywheel
Edelbrock RPM heads assembled
Hardened 80 wall push rods
1.6 extruded aluminum roller rockers
Polished air gap intake
MSD billet distributor
MSD blaster II coil and bracket
Demon 650 HP carburetor
Ford Racing 302 block
R&R pistons to rods
