Old 12-26-2010, 08:19 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by elgecko View Post
Installing a B&M auto shifter that has a micro neutral safety switch.
Can I wire this up with the 12 ga. wire coming from ign. switch S post , into the micro switch and then to the firewall mounted solenoid switch for the starter?
Will the micro switch handle the amps? The switch has a rating of 15amps.
If not, can a relay be installed.
I do have a 12v, 30amp 4 post relay laying around.
Thanks
Dave
what are you going to do for reverse lights? have you considered the ford type neutral safety with the reverse light switch? looks like you have a C-6 by your photos.
http://www.cjponyparts.com/images/265/SW877.jpg
Fred B
