Old 12-27-2010, 06:21 PM
DAVID GAGNARD's Avatar
Originally Posted by Excaliber View Post
Brent would you clarify your comment on the Ebrock RPM heads? Do you mean they will flow enough air where they are not a major factor in this case (horse power), OR are they the primary limiting factor given the other specs or what???
Ernie:
These are the "basic" Eldelbrock heads, good, but not great out of the box..........with some serouis work they can be made to flow well, but then you could have spent the same money on a better set of heads to start with..........
Some refer to these heads as "entry level" aluminum heads........
There are iron heads out there that will do better!!!!!!!!
I'm guessing from 300 to 350hp tops depending on camshaft/compression and a few other things...........not bad for a 302 should be a nice dependable engine.........
David
DAVID GAGNARD
