Old 01-19-2002, 04:53 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Todd,
FYI:
The original DV went through so many rearends I lost count. That 1.51 second 60' time is a reall killer on rear ends. We went through semi-lockers, Auburns (that one made about 4 hard turns on a roadcourse and blew the clutches), and seriously modified 9" Fords. Finally, at the Viper Nationals we split the 9" housing in half on a launch.
All for naught. True-Trak/Lok, wanted me to try one of their rear ends and guaranteed it! Even to the point if we didn't like it they would refund 100%.
Bottom line, this unit has been marvelous! You will feel some very minor "clicking" going around corners at low speeds and you may even hear it. Not to worry, it just tells you the unit is working. Not that those two big wide black marks behind you wheels isn't evidence enough!
Just my 2-cents.
DV
PS I think the unit itself is around $750.00 ?? $1050.00 seems a little high for installation...or are you including the 31 spline axles?
