Old 12-30-2010, 09:36 AM
Dominik's Avatar
Dominik Dominik is offline
2200 lbs car, with driver.
The difference in spring rates, amongst others, can be attributed to different motion ratios (distance from damper mounting points in front are typically different to rear, as well as angles).
Ride comfort is typically dictated by front coil (rate).
If I don't respond anymore, that's because I can't log in
