Old 12-31-2010, 07:58 AM
Ron61's Avatar
Ron61 Ron61 is offline
Originally Posted by scottj View Post
Sure you could... but, he attributed it to... "Just sayin. Stock suspension, good install." Then consider that SPF specs the weight w/460 at 2660lbs + 112 for fuel + 220 driver and it's near 3000lbs already... so it's way over 2900 without any lead... not sayin it isn't possible... just sayin...
Scott,
You are correct about the weight, but I was running a small block with a lot of aluminum parts. I also never used lead weights as I had a high quality suspension under my car and could adjust it pretty much to achieve a balance. Not perfect but close enough that it handled better than any of the others around here. But like most people I could never be satisfied with what I had and kept tyring things to improve it. I wish I had it back now as that is the only car I ever sold that I hated to see go.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
