Old 12-31-2010, 01:00 PM
Silverback51's Avatar
Silverback51 Silverback51 is offline
Originally Posted by RET_COP View Post
......Is 50/50 optimal?
I think of a car like the GT40. with the mid engine, it must have been rear heavy yet I read where it cornered great
Lou
Is 50/50 optimal?
That is a yes/no question. There are so many factors in the equation that there is no one answer. The variables range from tire size and spring rates to the CG of the vehicle. For that matter tire pressure can have an influnce on how the vehicle handles.
Let's take the GT40 as an example. It is far from being 50/50 as it's a mid engined car. But then you look at the tire sizes. Much larger in the rear than the front. Not unlike a F1 or Indy car. Now look at a NASCAR (as much as I hate to refer to them) car. All four tires are the same size and I'm willing to bet the car is close to 50/50 weight distribution, with a side to side bias due to them only turning to the left.
Since a Cobra is not able to run same size tires front and rear (and by size I mean tread width) you would generally want a little more weight on the rear. The spring rates would be such that under acceleration you transfer the weight to the rear of the car for traction. The same is true under braking for a corner. The weight is transferred to the front to help in the braking and turn in at the beginning of the corner if you are trail braking.
Hope that helps a little, and didn't just confuse you more.
John Hall
