Old 01-03-2011, 03:01 AM
albanycobra's Avatar
albanycobra albanycobra is offline
Default Jag Diff rebuild specs
Hey Guys
I'm freshening up my Jag diff with new bearings. I'm hoping someone can give me the specs for the the following
Diff I have is a salisbury 3.3 ratio powerlock, 5 bolt output
shafts with single large bearing.
1- Crown & Pinion Back lash
2-Carrier bearing preload / clearence
3- Pinion nut torque
4- pinion bearings rotating torque
5- out put shaft bearing retaining nut torque ( I have the large
single bearing
6- Output shaft flange to diff housing feeler gauge clearence.
Dave
