Old 01-06-2011, 10:16 PM
Rebel1 Rebel1 is offline
Some of the guys have wired the steering lock/ignition on the column and a dash mounted start button together. ie.You turn the ignition key to the start position (steering lock is then disengaged) but the starter solenoid active wire is via the start button, not the ignition switch.
Still leaves you with the column key which is maybe what you don't want.
