Old 01-07-2011, 08:43 AM
lemans24 lemans24 is offline
Cobra Make, Engine: kirkham stroker 48 webers
On your linkage, make sure you push the gas pedal all the way down to the floor with out having it connected to the carbs (holding it to the floor), then work out the length of the linkage to the bell crank etc. so as to not pull the linkage too far when flooring it.You probably already thought of that, but I would hate to see your carbs get stuck wide open.
