Thread: 402w stroker
Old 01-07-2011, 12:10 PM
Jimbocobra's Avatar
Jimbocobra Jimbocobra is offline
Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
Default 392 with AFR heads got 537hp
Good luck with the engine, here is a good comparison for you to start from. This article is from Muscle Mustangs and Fast Fords and details an otherwise stock 351 Windsor stroker also with AFR 205 heads that got 537hp. It is "only" stroked to 392 and was only 9.5:1 compression. You are going to be running a few more cubes and higher compression, so I'd say to expect at least these numbers. Hope that helps give you a baseline. If not, keep tuning it until you do or something went wrong. Frankly, I'd expect whatever Keith and Brent said to expect - you have two of the best engine builders in the country chiming in.
http://www.airflowresearch.com/artic...e004/A4-P1.htm
1/4 mile 11.92@115.6 and 60ft 1.632
