Old 01-07-2011, 01:07 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Bill Cuthbertso View Post
I really think that there is no really correct position for the third hole. I think that the upper area is a convenient place to put the hole because there is alot of room.
If you turn carburetor upsike down and watch the butterflies open, you will see that the progression holes are not opened in sequence. All three are open to the vacume at the same time so I do not think it matters to much if at all. The size of the hole certainly does matter. 12 o'clock seemed to work for me, but I think 2 o'clock will also work. I used 12 because it was easy to eyeball that location from carb to carb.
Lets hear your thoughts.
Bill,
Others will agree that all of the progression holes are exposed one at a time.
Originally Posted by dlampe View Post
I sent you a PM weeks ago about renting the tool. I guess you are not open to that.
I have 2 carbs that have a threaded port and 2 carbs that are plugged and I don't know if they are threaded behind the plug or not. Any ideas?
I'd say a plugged progression port would have no threads, cheaper to make.
Gary
