Thread: 402w stroker
Old 01-07-2011, 03:32 PM
blykins blykins is offline
Originally Posted by madmaxx View Post
I am sure I will get flamed but some of the best lifters on the market are standard ford racing. About $140 for set of 8.
I would agree with that for SBF's....unless you're going old school without a spider and need link bars.
As for spring pressures, if you're just going to 5500, 170 lbs of seat is not necessary. Sure you can run 170/450, but for something that peaks at 5500 rpm, there's no use in adding more wear factor.
For most SBF's, even with the heavier valvetrain, 150-155 lbs of seat will get you 6 grand and then some.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
