Old 01-07-2011, 06:08 PM
Zedn's Avatar
Zedn Zedn is offline
Warren,
I havnt heard of the clubby column and i do spend a bit of time on the clubby forum. I will ask some people i know.
Outwest,
I like the brake idea. However to pass the ADR you would need to make it so you cant remove the key without the lock being activated. That is the tricky part. My outlander requires the car to be in park before the key can be removed, maybe it would be the same sort of thing but hooked up to brake light circuit. There is still a problem however that the solonoid could malfunction and clamp the brake line whilst not depressed and lock it off. I suppose if it was only on the rear that wouldnt be too bad a problem.
Liam
